Overlap Receiving Issues / No busy signal
I have a problem with overlap receiving at german ISDN if the called extension is busy. The extension are configured with huntstop channel.
As described in this document my incoming calls working fine:
https://supportforums.cisco.com/docs/DOC-25562.
But if someone is calling a extension which is busy the incoming caller hear only silence.
I already debugged it and I can see that the isdn call is connected(to the telco) before all digits are received and after the CME identified the extension and see that the line is busy it is to late to send a ISDN busy packet back to the provider.
The result is that the call is somewhere lost in the CME.
I found another document which describes the problem:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b58.shtml#busytone.
Does anyone have a solution for this? Perhaps can I generate a busy tone instead of the isdn message packet.  Or is it possible to route this call to my hunt-group or to another extension?
best regards
Christian
- Please rate helpful posts -
9 Replies 9
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
You should configure so that all the digtis are received before the call is connected. That will allow CME to send the subscriber busy message.
Hi Paolo,
can you tell me which parameter I need to modify for that?
interface BRI0/1/1
description ISDN AA
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 6000
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
trunk-group ISDN
best regards
Christian
You need to look at dial-peers, transalation rules, etc.
that's the dial-peer and translation-rule
dial-peer voice 5 pots
trunkgroup ISDN
translation-profile incoming ISDN
incoming called-number 4568[0-9][0-9]
fax rate disable
voice translation-profile ISDN
translate calling 2
translate called 1
voice translation-rule 1
rule 1 /^4568\(..\)/ /\1/
rule 2 /^45680/ /80/
rule 3 /^.*$/ /80/
voice translation-rule 2
rule 1 /^\(.*\)/ /0\1/
Don't know where I can delay the system to wait for the digits to send busy signal.
best regards
One would need to see debug isdn q931 and debug dialpeer output.
Also you should apply the translation under voice-port or trunk group, not dial-peer.
I attached a debug.
1st part of the debug
One active call (connected to Ext. 28, simulating the busy)
to: 456828
One call in (should hear busy, but only silence)
To: 456828
2nd part of the debug
To: 456828
One call in (hear busy, everything fine)
to: 456828
regards
Christian
To have a readable trace , would need only the debugs asked above and nothing more.
Otherwise you can contact Cisco TAC for support.
Hi Paolo,
sorry that is the only debug I have at the moment. Because the problem happens only from particular lines I don't have the option to the test it agian for the next time.
regards
Christian
Yes, it happens only when calling from analog fixed lines, that generate overlap dialing.
