panel touch 10
luisgonzalez2
Estimated very good afternoon,
I need your help, I have a touch panel 10 connected to a sx20 version 9.1.4, the computer I have access pin and thus block access from the touch panel to the advanced settings, but I have a pending issue when blocking alone the configurations. I need to know if there is a way to remove the reboot from the touch panel as users continue to perform this action. agredecere your answers,
thank you very much
Patrick thank you very much for your response.
anyway I send the information that I got from part of cisco through the TAC.
Luis.
I inform you that the next version CE9.2.0 will contain a "macro framework", in which you can add / remove features through Java programming, with this you will be able to change all the settings of the way touch panel that your client needs,
I clarify the following points:
Ce9.2.0 is only available for SX, MX g2, mx 800/700, DX series
C series, EX series and MX g1 series do not have this feature as they are incompatible with ce8 / 9
At the moment the estimated release date of this software would be "2017-11-01" (may be subject to change)
Actually here we are excited, as there will be no need for customers to open enhancements requests, but for what they need extra, program it by Java,
best regards
Patrick Sparkman
It's not possible to hide or remove the restart button on the Touch 10. Suggest you contact your Account Manager and have them open a feature request for you.
Thank you very much for your answer Patrick
following the same line, also eliminates the camera brightness function from the touch panel,
Is it possible to reactivate it?
why did I remove it in this software version?
attentive to your comments and thanks for the early reply
The Touch 10 UI was redesigned in CE9.0, as a result there are some feature gaps between the design in CE8.x.  Some features are slated to be added later, some are not and must be changed via the endpoint's web interface, there is a list in the CE9 Release Notes.  Camera brightness is one of the features that will not come back and must be changed via the web interface.
Luis.
best regards
