PE Password Generation
Justin Ferello
Level 5
Level 5
All,
I must be missing something, I have "Enable Password Generation" turned to on for (2) seperate PE installs, but every time I create an account the password field is always blank.  I am seeing this in two totally different installs.
Thank you,
Justin Ferello
Technical Support Specialist
KBZ, a Cisco Authorized Distributor
http://www.kbz.com
e/v: justin.ferello@kbz.com
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
Martin Koch
You write "create an account". I would expect the behavior similar to the legacy
TMS Agent setup, where passwords are only auto created on an AD import.
Manual account generation = manual password setup.
I would try to get them to use AD import of accounts and also password handling via AD&VCS.
Martin Koch
Martin,
You are probably correct, I alwasy forget that import from AD does not include passwords, so TMS has to generate random ones.  For some reason I always assume that importing from AD brings username & password
Thank you,
Justin Ferello
http://www.kbz.com
Thank you,
Justin Ferello
Justin, have a nice weekend
