Ports Usage between TP Infra and endpoints
Driss BENATTOU
Enthusiast
Enthusiast
I have TP Infra Behind Firewalla and endpoints distributed along sites.
I need all flows and interactions between endpoints and Infra (VCS, MCU, TMS). Otherwise, I have to know all TCP/UDP ports used between Infra and endpoints so that i have to open them at Firewall.
Driss
mahkrish
Participant
Participant
Hi Driss,
1. Please find the TMS ports utilization list.
2. For VCS port utilization you can refer to the following document.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X7-2.pdf
3. For MCU port utilization you can refer to the following document.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/conferencing_products_conferenceme_ports_used_kb_3.shtml
HTH.
BR, Mahesh Adithiyha
Recognize Your Peers
