Prime Collaboration Manager - Jitter/Packetloss/Latency on CTS-1300
t.svatek
Level 3
Level 3
I´ve installed a Prime Collaboration Manager and added a CTS 1300 1.8.0 to the inventory.
I got some events regarding periphals, but no events regarding Jitter, Packetloss or Latency,
although there are such entries in the CTS-1300 Sysop log.
thanks
Tino
Rafal Szeremeta
Hi Tino
Can you attach couple of screenshots? What version of CPCM you have?
Rafal
Hi Rafal
I was able to enable this by adding the CUCM to get the Session Info. Should this also work for Ex-Tandberg-Devices on VCS?
thank you
Tino
Hey Tino
Yes, just please make sure you add VCS (x6.0 or higher) first and CPCM should discover all devices registered on VCS.
Please check those links as well:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6491/ps11433/ps11480/data_sheet_c78-708410.html
http://www.cisco.com/en/US/docs/net_mgmt/prime/collaboration_manager/1.2/user/guide/Cisco_Prime_Collaboration_Manager_User_Guide_1_2.pdf
Cheers!
Rafal
thanks, Rafal
