03-25-2005 08:51 AM - edited 03-17-2019 08:24 PM
I have a 2851 that has a PRI connection to a NEC PBX. That NEC PBX has 3 BRI trunks that connect to a Tandberg Video Unit. The 2851 Also has a connection to the PSTN. We want to be able to call from the Video Unit and call out to the PSTN. This Use to work, but now all we can do is, when we call, the video connects but it only connects at 64K,(so only one channel connects). I don't know what changed, but for what ever reason it stop working. But incoming calls work fine, just outgoing does not work.
Here is a debug isdn q931 for an out going video call,
aaa-voip(config-voiceport)#
*Mar 25 14:08:21.900: ISDN Se0/1/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0100
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98392
Exclusive, Channel 18
Called Party Number i = 0xA1, '7034353825'
Plan:ISDN, Type:National
*Mar 25 14:08:21.912: ISDN Se0/1/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x
8100
*Mar 25 14:08:21.932: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x3 is
0x2 0x1, Called num 7034353825
*Mar 25 14:08:21.936: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x2417
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
*Mar 25 14:08:22.264: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x
A417
*Mar 25 14:08:23.412: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callref = 0xA
417
Progress Ind i = 0x8488 - In-band info or appropriate now available
*Mar 25 14:08:23.420: ISDN Se0/1/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8
100
*Mar 25 14:08:27.368: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xA4
17
*Mar 25 14:08:27.368: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref =
0x2417
*Mar 25 14:08:27.372: ISDN Se0/1/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x81
00
*Mar 25 14:08:27.408: ISDN Se0/1/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref =
0x0100
*Mar 25 14:08:33.368: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected
to 7034353825
*Mar 25 14:08:42.500: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0
x8337
Cause i = 0x8090 - Normal call clearing
*Mar 25 14:08:43.220: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x03
37
*Mar 25 14:08:43.220: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x8337
any Ideas?
03-31-2005 08:22 AM
Make sure there is no change in the Video Codec used. Also check whether the video unit is requesting for correct bandwidth.
04-04-2005 08:31 AM
Try using the 'bearer-capability speech' command on the Voice Ports between your router and PBX/PSTN.
http://www.cisco.com/en/US/customer/tech/tk652/tk701/technologies_tech_note09186a0080093f62.shtml
04-18-2005 04:30 PM
This should work fine, though there are a couple of things that need to be set up properly. We did some extensive lab testing with a Polycom unit and running calls over 3 BRI ports (6 B channels) and got it working for inwards and outwards calls.
The router will handle an ISDN data call bearer cap and drop the DSP after the call has connected so you get a pure PCM connection.
By the look of it you are hairpinning the call from one PRI port to another, so you need to ensure the clocking is set up correctly as clock slips will kill data calls. Can you post your router config so we can confirm how things have been setup.
Here is an app note that give a bit more information on TDM hairpinning, we will updating the note with details on the ISR routers soon.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080387544.shtml
04-20-2005 05:13 AM
Thanks for the input, I put the bearer-cap Speech under the port that connects to the PBX and that worked. However doing a Shut/No shut on the port did not work. I had to do a full reboot of the router for it to start working. thanks for the info
07-07-2006 12:35 AM
hi all
your link is not working. have you an updated document for me ?
09-11-2006 01:04 AM
hi
the link
is not working.
can you send me the dokument ?
kind regards & thANK YOU
07-07-2006 12:33 AM
Hi all
i saw your conversation about ISR & hairpinning for Videoconferencing.
Is it possible that you provide me your working configuration ?
many thanks
