Proxy SIP registration messages {Jabber video for TelePresence}
Simon Battye
Level 2
Level 2
Is it possible to proxy SIP registration messages for Jabber video for Telepresence via this route:
VCS-Expressway -> VCS-Control -> Neighboured VCS-Control.
Both VCS-Control's are provisioned with TMS but the two servers manage alternate domains i.e. (.*)@(location).(domain)
Only a single VCS-Control is peered with the VCS-Expressway as the VCS-Controls are in different regions, the VCS-Expressway does not have a SIP domain configured and it is already proxying SIP registration messages inbound to VCS-Control OK.
The two VCS-Control's are neighboured and the authentication policies are configured as:
VCS-Control: do not check credentials
Neighboured VCS-Control: check credentials
Search rules are matching the uri's OK.
Thanks, Simon
Paul Woelfel
Level 4
Level 4
This should work fine, if you set the SIP proxy method to "proxy to known only" on you Control and Expressway. With that setting the registrations will be proxied according to your dial rules, if the domain is not found on the VCS.
Regards, Paul
