08-19-2015 08:29 AM - edited 03-18-2019 04:52 AM
I have Cisco 1841, 1 wan and 1 lan, I want to apply Qos/Auto Qos to prioritize Voice, I googled it but don't know where to start? Do I need to enabled it on both interfaces?
Thank you.
08-19-2015 11:29 AM
Keep in mind you can really only do "meaningful" QoS on outbound traffic.
Depending on the version of IOS you should have access to the "auto qos voip" command while in interface config. Arguably the most important place for QoS is facing the WAN, since it is often the bottleneck compared to the LAN. That being said QoS needs to be present on switches and other gear to work "properly".
Catalyst switches also have auto qos capabilities, which allows them to trust markings from certain devices among other things.
QoS is a complicated topic, so this is why Cisco made auto qos. Cisco phones are configured by default to mark their signalling traffic and voice bearer traffic, so as long as the switching infrastructure isn't overwriting/resetting this auto qos on the router will match these markings and give them priority. It's critical that your interface config defines the actual bandwidth or QoS won't have any idea when congestion is occurring.
A good place for you to start reading is probably http://www.ciscopress.com/articles/article.asp?p=352991&seqNum=5
08-20-2015 04:07 AM
Thank you Anthony!
I'm a newbie so maybe you can share some sample config. I am working on a callcenter with a connection of 10mb fiber up/down, data and voice are on the same connection, we will be using a hosted PBX that is why I want to enable voip prioritization on our network. We will be using softphones, no cisco phones. I am using cisco network assistant and looking for QOS settings but I cannot find anything for me to begin with.
Here is our setup:
cisco 1841---catalyst 3548-XL12.05(distribution switch)---proxy server---catalyst 3548-XL12.05---lan pcs
Where should I start?
Hoping for your advice.
Thank you.
08-20-2015 08:37 AM
On the catalysts it looks like you're pretty light on what you can do for QoS, I've never worked with this platform so I can only go off of what Cisco indicates in their documentation: http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2900-xl-series-switches/23060-139.html
In interface config you can try auto qos voip cisco-softphone but I suspect it won't exist. You're not going to have much fun or luck configuring QoS for softphones on these switches, you can do priority queuing for output on these but since these are softphones the PC data would end up in the priority queue as well, not at all a good thing. These switches don't support COS to DSCP mappings either. On top of this the switches don't support voice VLANs, so I'm going to say as far as the switches you're out of luck for the most part. That being said according to the Cisco docs the switches will just leave the DSCP value untouched, so assuming the soft phone is marking it's packets (Cisco IPC will) you can match these values at your router...
It can be really simple on the router as mentioned earlier, just go into interface config for you Cisco router and type "auto qos voip". This tells the router to generate a bunch of config that does the following:
And voila, you have a simple but working QoS configuration. To test this configuration is matching properly, use "sh policy-map interface xxx" where xxx is your WAN interface. Look for matches in the classes. You should also test this during times of congestion, so use a traffic generator of sorts on the LAN and check voice quality between a soft phone and a PSTN caller. There should be minimal delay in the caller hearing your voice, anything over 150ms delay one way is generally considered unacceptable.
The above is all based on my experience, and my understanding of Cisco's recommended practices, others may provide a different take or have some suggestions on how to get something useful out of the switches.
08-23-2015 02:33 PM
Hi Anthony! Thank you for lending your time to answer my questions. I still have a couple of questions, have auto qos setup just need some testing.
1. auto qos voip vs. auto qos voip trust, what is the difference?
2. you can really only do "meaningful" QoS on outbound traffic--- so auto qos is not the best way to do prioritization on voip.
3. is there other way we can do prioritization? like reserved bandwidth for sip?
Thank you again!
08-23-2015 03:29 PM
09-24-2015 04:24 AM
Hi Anthony,
Sorry for bothering you.
Been doing a lot of testing on QOS, can you recommend a managed switch that has QOS?
TIA
