Quad Cam and SpeakerTrack kit in same system
tbott
Is it possible to have a regular SpeakerTrack P60 kit and a Quad Cam connected to a single codec (WebEx Codec Pro) and be able to switch between which one is the active camera system?
Yes you can connect  both quad cam and P60 to a codec pro.
Response Signature
Sorry, might have not been as clear as I should've been.  This isn't connecting just a P60 to a codec with a Quad Cam, this is connecting a dual p60 SpeakerTrack system and a Quad Cam to the system at once.  My thoughts are the codec likely won't like two different SpeakerTrack systems connected at once, I'm just trying to get confirmation.
