Quick Set C20 - callRate 1024Kb/s?
Saludos, tengo un endpoint Cisco Quick Set C20. Éste terminal tiene la posibilidad de hacer llamadas a 256, 384, 512, 768, 1152, 1920, 2048Kb/s.
Vía telnet puedo agregar contactos y settear su velocidad a 1024 Kb/s, sin embargo al buscarlo en el phonebook vía remote control, este contacto figura a 768Kb/s.
Vía telnet puedo realizar llamadas a 1024Kb/s con el comando xcommand Dial Number: 55.11.7.95 CallRate: 1024
Existe alguna manera para poder llamar a esta velocidad sin necesidad de conectarme vía Telnet?
Hay alguna opción que me permita habilitar dicha velocidad?
A todos muchas gracias.
With the Web Interface, or via telnet.ssh, you can change the default call rate on the SX20 to 1024 - that way you will not need to specify it in the phone book, or each time you dial.
In the web interface this can be found under Configuration > Conference > DefaultCall, and set the Rate field to 1024.
Via the command line, you can use the following command:
xConfiguration Conference 1 DefaultCall Rate: 1024
EDIT: Apologies for dragging up an old thread - i didn't notice the sort order on the forums had changed and was showing ancient threads at the top of my list.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
