"Previewing Input" Bar
t.schwebinghaus
Hello Everyone,
is there anyway to disable the yellow Bar "Previewing Input X" when previewing and not sharing any content on a SX80.
I feel, like I've read the whole manual now ;)
Thanks in advance.
Bests
Max Welskop
6 Replies 6
Patrick Sparkman
I've never seen a yellow bar saying "Previewing Input..", can you provide a screenshot?
EDIT: I see it now, it's on the output of the video, I was looking at the Touch 10.  I checked through the admin and API guides, and I don't think there is a way to remove that since it provides a visual indication that you're previewing the presentation content and not sending it to the far end.  Suggest you contact your Account Manager and see if they have an idea, they can create a feature request for you if you really would like the ability to disable the notice.
Here's the screenshot once again.
Thanks for your help!
Yeah, I saw it and updated my previous reply when I did, was just looking in the wrong place.  As I said, there isn't a way that I found to disable.  Should contact your Account Manager and have them create a feature request for you if it's something you possibly want implemented.
Oh hey, thanks. The forums seem to be a bit out of sync today ;)
Thanks for your help. I'll do that!
Yeah, forums have been acting a bit strange.
If you're question is answered, don't forget to mark relevant posts.  Also, if you find anything out when you speak to your AM, let us know.
t.schwebinghaus
Hi Patrick,
I attatched a screenshot.
Any ideas?
