Ready for VoIP?
t.akin
Hi all,
is there overview from cisco about hardware and software requriements for implementing VOIP?
I must check if our network is ready for VOIP.
Thx
Taylan
scottmac
Level 10
Level 10
If you are planning a full deployment of VoIP, in addition to verifying the equipment and software list, Id recommend doing end-to-end testing ... even if you control the entire network.
Agilent has a 'VoIP Quality Tester" that will give a full analysis of the endpoints. Buy one or rent one (or get a consultant that has one) .. having the right hardware/software is only the starting point; optimizing the overall network is probably going to be necessary ... lots of tweaking configs, routes, and loads.
I'd also recommend some serious prototype and piloting.
Good Luck
Scott
tepatel
It all goes by whay is the requirement behind using VoIP OR What exactly the goal behind using VoIP. Based on that the solution will be provided.
There are many solution available based on requirement. Visit following url for that
http://www.cisco.com/en/US/netsol/ns110/ns163/net_solution_home.html
On that link you will find many many solutions and related docs as well. Check on the left side tabs on that doc
