Rebotting MCU 4200
ruberdi_v
Hi Everyone,
I have an issue with one of the MCU, at our customer place, where it is automatically rebotting in every 5 minute. Web accessible.
Ruberdi
Right at the end of your log file it appears that you don't have an activation key installed:
Warning : Product activation key required
Are you able to connect to the device via the CLI or web interface to check the key that is installed is present and/or correct?  Can be seen on the Settings/Upgrade screen under Feature management.  You should see Activated features: MCU 4210 activation (XXXXX-XXXXX-XXXXX-XXXXX).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Wayne.
I've done config_reset. This don't have an activation key.
I have attached a detailed log file
You will need to have the activation key installed for the device to function.
You should be able to get this from the Cisco Licencing Web Site or the TAC.
Wayne
Wayne
