Recording with the C40
tufan.kabacioglu
Beginner
Beginner
We are planning to offer a customer a few C40s with 3rd party recording solution. The recording solution is a capturing software working with a capture card. We connect the second display output of the codec to the PC. I know C40 now supports recorder output. But we need to record only local video not remote audio. Is there a way to change video sources which will being recorded on the recorder output with C40?
Thanks and regards,
Tufan
Martin Koch
Advocate
Advocate
Hi Tufan,
your text confuses me a bit: "But we need to record only local video not remote audio.".
Are you aware of the tc-console? The c40 has some limitations in comparison to the c90 and c60.
http://developer.cisco.com/web/telepresence-developer/tools/integrators/tc-console
I never tried it wwith a c40 but maybe you can at least use tc console to learn about the api commands used on
the bigger codecs to set a specific layout and sound setting which suits your requirements.
The developer forum might be a good sport to ask further questions:
http://developer.cisco.com/web/telepresence-developer/forum/-/message_boards/category/5354383
Please remember to rate helpful responses and identify helpful or correct answers.
