Registration DX70 with Expressway-C
Yanes ABDELLI
Hello Cummunity,
I'am actually facing a probleme of registration a DX70 Endpoint with an Expressway-C.
I regestred a DX80 with a CE8.3.1 Software, but the DX70 has an Android software. So the probleme is that I can't define a SIP Proxy and URI to regester in the Expressway-C.
Note: I'am using the Expressway-C as a SIP registrar with Desktop-Licence nd Telepresence-Licence.
Do you have an Idea about that ?
Thank you for your help.
Justin Ferello
Level 5
Level 5
Yanes,
You cannot register Android DX units to any VCS; they only act like phones.  You must convert the Andriod based DX to CE software to be able to register to a VCS.
See this guide for mor information:
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce82/dx80-dx70-convert-between-CE-android-based-software.pdf
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
Thank you Justin,
It was very helpful.
