03-10-2022 08:40 PM
Hello Team,
I am looking to remove Sign IN option from CMS WebRTC for all, is this possible ?
Thanks for advance.
Solved! Go to Solution.
03-11-2022 04:13 AM
And have you also bound the webbridge profile to the webbridge?
By just adding a new webbridge profile it won't do anything...
03-10-2022 11:04 PM
In the API object "webBridgeProfiles" you can set the parameter "userPortalEnabled" to false.
Then, when someone opens the WebRTC URL, he will straight see the MeetingID and password fields
03-11-2022 01:28 AM - edited 03-11-2022 01:28 AM
Hello Winter,
If i set this parameter false then it will disable sign in option for Webadmin or WebRTC or both .
03-11-2022 02:27 AM
Only for the WebRTC site
Webadmin site is a completely different site.
03-11-2022 03:41 AM
Hello Winter,
Thanks for sharing this but still i can see Sign In option , for get i getting below response.
(Not able to attach image )
03-11-2022 04:13 AM
03-11-2022 10:16 AM
Hi winter ,
Yes you are correct ... 1st create webbridgeprofile and then associate that profile in webbridge .
