ā09-10-2012 07:50 AM - edited ā03-17-2019 11:46 PM
Dear All;
we have MCS7816I5-K9-CMD2 server, and we had installed unity connection 8.5 successfully and it operations fine, but it works on demo license;
My question is: what is required license needed to purchase to support the 255 voice port, now it can be used 2 only.
Thanks in advance;
Rashed Wardi
ā09-11-2012 07:03 AM
I don't see that as a supported server, and either way, a 7825 cannot support more than 48 ports. You cannot possibly expect a 7816 to handle 255 ports.
Cisco Unity Connection 8.x Supported Platforms List
If you still want to pursue this, you can get in touch with pre-sales
www.cisco.com/go/ph
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā09-11-2012 07:49 AM
thank you javalenc,
Actually 20 ports is enough for us, but if I purchase the licese for 7825 server, does it will work on 7816 server.
please advise me ;
BR,
