Reset IM and Presence service on Exp-C
Mike Assel
Level 4
Level 4
Occasionally I will see an error in my Expressway Core related to the XMPP router connection to the IM&P server.  A restart of the Expressway has always fixed it, but I was wondering if there was a way to restart that service without restarting the entire box.
Thanks,   Mike
Manish Gogna
Hi Mike,
You can try the following and see if it helps:
FFrom Expressway−C, go to Configuration > Unified Communications > IM&P Servers
. Select the checkbox next to each IM&P server and click Refresh servers.
Manish
Manish Gogna
Hi Mike,
Manish
Ahhhhh.... Don't know why I didn't notice that before.  I'll make sure to try it the next time the connection is down.  Thanks much!
Yep, confirmed that this works.  Thanks.
Good to know that, thanks for the update.
Manish
