Room Kit activate standby by one click on touch10
clauspedersen1
Hi all
Theese days lots of customers want to save energi , and in that case they actually activate the system standby mode
when leaving the meeting. This is activated by three clikc on the Touch 10.  Have anybody made an macro for activating standby mode by one click (red dot ish) on the touch 10 ?
Thanks in advance
Claus Pedersen
Tobias Gramckow
Hey Claus,
I recently wrote a macro for this case. You can find the code attached in the textfile. Once you activate the macro on the endpoint, a button is getting created automatically.
Greetings,
Tobias
Yes - just use the UI Extensions Editor to create a button (in my example, I called it "Standby_Button").
Then use a macro such as this one:
import xapi from 'xapi';
xapi.event.on('UserInterface Extensions Panel Clicked', (event) => {
 if (event.PanelId === 'Standby_Button') {
 xapi.command('Standby Activate');
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
