Room Readiness Assessment Kit
James Hawkins
Level 8
Level 8
Does anyone know who the company is that produces the TelePresence Room Readiness Assessment Kit?
I believe that they are in California - if anyone can provide details and hopefully a link I would be really grateful.
t.svatek
Level 3
Level 3
Hi James,
Pacific Radio Electronics
Maybe, there is a newer version available, but this is what I´ve ordered in 2009:
Tool Kit Part Number: PAC-CTS.RRAv1
Components of Tool Kit:
• NTI Acoustilyzer AL1 - Acoustic Analyzer and Tone Generating CD (Laptop or CD Player
required)
• NTI Mini SPL - Condenser Microphone to accompany Acoustic Analyzer
• NTI Minirator MR1 Tone Generator - Note: this item is Optional but recommended.
• Fostex 6301D - Portable Monitor Speaker (only one required)
• Cable to connect laptop and speaker - 1/4” TRS – 3.5mm TRS (at least 6 feet or 2 meters)
• Cable to connect Minirator MR1 to Speaker - 1/4” TRS – RCA (at least 6 feet or 2 meters)
• Extech 407026 Light Meter
• Carrying Case - Pelican 1510 with Pick’N’Pluck foam for a custom fit
cheers
Tino
t.svatek
Level 3
Level 3
Hi James,
required)
cheers
Tino
Tino,
Thanks - exactly what I needed to know
btw: I would recommend to use a Speaker with more Power. The Fostex is reaching it´s limit with RT60 Tests in bigger rooms.
