RoomKit calls to Webex via Expressway no video
samhopealpha
Level 2
Level 2
Hi Everybody,
Connection path
RoomKit Plus --- CUCM --- ExpC--- ExpE --- (internet) --- Webex
The audio call from Roomkit to webex is fine.
However, the video does not come up on both endpoint.
I have checked the SIP INVITE signal,
CUCM received the (INVITE) SDP video attribute in from RoomKit
But the (INVITE) SDP video attribute was disappeared during CUCM sent to ExpC
I did verify the CUCM's region setting between Endpoint and SIP trunk (to ExpC), both should be maximum value
  • Maximum Session Bit Rate for Video Calls: 32256 kbps
  • Maximum Session Bit Rate for Immersive Video Calls: 2000000000 kbps
All devices' location is "Hub none"
I don't know why CUCM won't send video attribute to ExpC ... and not sure is it the root cause of video fail
Is anybody can help?
Thanks in advance
Sam
samhopealpha
Level 2
Level 2
problem is resolved after remove the mtp
samhopealpha
Level 2
Level 2
