ROOT ACCESS TO MXP F9.3.4
Chet Cronin
Level 4
Level 4
Is there a group root access password for F9.3.4 firmware?  I have about 100 systems need to take action on.
I have to remove the following config_file ....   /etc/ssh/sshd_cfig file    DES CBC3 SHA RSA ECDHE CBC
VR
Chet
Chet Cronin
Patrick Sparkman
MXP endpoints don't have a root account, and it's not possible to access their file system, see remove-64bit-block-cypers
Thank you ...
VR
Chet
Chet Cronin
The MXP endpoints don't run a Linux based operating system like the TC and CE series software devices, so there is no "root" account to be able to log in to like there is on the newer endpoints.
The MXPs run a modified eCos OS which isn't accessible via the usual means, so unless it is patched by Cisco, then there's not a lot you can do about it without taking other steps to remediate the issue.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
