03-03-2013 03:10 PM - edited 03-18-2019 12:42 AM
I'm trying to write some user guides for our EX90s that are using TC6, and it would be very useful if I could get some screenshots of the Touch 8".
I've seen this thread: https://supportforums.cisco.com/message/3649899#3649899 that relates to taking screenshots from TC5.1, but it doesn't seem to work in TC6 (it just gives 404 - not found when browsing to http://ip_address_of_codec/wsgi/translation .
I have web snapshots enabled from the administrator settings.
Is there an updated method for the new software?
Solved! Go to Solution.
03-03-2013 03:16 PM
Replace the wsgi bit with "web" instead.
Guy
03-03-2013 03:16 PM
Guy
03-03-2013 03:34 PM
Thanks, worked first time!
Now that I look at the URL structure of the new interface that seems obvious
