Security phone DTMF issues.
mnour401917_2
Beginner
Beginner
Hi ,
I am having issue with a monitoring company phones that connect to our Cisco IP Tel Network.
The phone calls the monitoring company and sends a client ID digits using DTMF. I did some debugging “debug voice ccapi inout” and I see duplicate DTMF messages sent.
For example the phone is programmed to send only “1119” as a client ID, but on the debug I see duplicate numbers and other numbers that the phone is not programmed to send. The Monitoring company system will then fail to recognize the DTMF message sent to them and Alarm call will fail. See below.
We tested this on a normal PSTN line and it works fine.
CCM version is 4.1, voice Gateway is 2811 – H323 (PRI)
Phones are connected to VG248 and another phone on ATA186
Any help will be much appreciated.
Mohammed
046921: *Dec 22 05:54:08.236: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x5F22
046922: *Dec 22 05:54:08.336: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046923: *Dec 22 05:54:08.436: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046924: *Dec 22 05:54:08.536: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046925: *Dec 22 05:54:08.636: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046926: *Dec 22 05:54:08.736: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046927: *Dec 22 05:54:08.836: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 9 to dstCallId 0x5F22
046928: *Dec 22 05:54:08.936: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046929: *Dec 22 05:54:09.036: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046930: *Dec 22 05:54:09.136: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046931: *Dec 22 05:54:09.236: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x5F22
046932: *Dec 22 05:54:09.336: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046933: *Dec 22 05:54:09.436: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046934: *Dec 22 05:54:09.536: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046935: *Dec 22 05:54:09.636: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046936: *Dec 22 05:54:09.736: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046937: *Dec 22 05:54:09.836: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046938: *Dec 22 05:54:09.936: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046939: *Dec 22 05:54:10.036: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046940: *Dec 22 05:54:10.136: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046941: *Dec 22 05:54:10.236: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046942: *Dec 22 05:54:10.336: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046943: *Dec 22 05:54:10.436: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
046944: *Dec 22 05:54:10.536: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046945: *Dec 22 05:54:10.636: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 7 to dstCallId 0x5F22
046946: *Dec 22 05:54:10.736: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
046947: *Dec 22 05:54:10.880: //24353/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
mnour401917_2
Beginner
Beginner
Can anyone help please?
Any thoughts will be much appreciated.
Mohammed,
  Did you ever get an answer on this? I've got something very similar.
Thanks!
Mike.
us as well.
