Send messages and collecting feedback from the rooms using API xCommand UserInterface Messages
Hi, everyone!
I'm quite new to using the rooms API, so, what I'm asking may sound easy to you. Here's what I'm struggling with:
- Send customized alert to the rooms using xCommand UserInterface Message Alert Display.  I'd like to have a way to quickly send a predefined custom alert to the rooms. First I tried using a .bat script like this: "putty.exe -ssh user@addess -pw password -m c:\path\command.txt" in the txt i had: "xCommand UserInterface Alert Display Title:”Title" Text:”Text” Duration:30" I had no success with that, is there another way to do this?
- Ask for feedback from the users in conference using xCommand UserInterface Message Prompt. This one is the same problem that I had before, the .bat script doesn't work. Also, I don't know where I'd collect the feedbackId.
I'd like to send this messages to all kind of endpoints, SX10, SX20, SX80, Webex Room Kit and Room Kit Plus.
Thanks for the attention, sorry for a lot of begginer questions!
Best regards,
Alexandre Ferraz
Wayne DeNardi
You're missing the "Message" part of the command
xcommand UserInterface Message Alert Display Title: "Test" Text: "Message" Duration: 30
There are different ways of collecting feedback, there are examples on GitHub such as https://github.com/tloyau/feedback-meeting or https://github.com/CiscoDevNet/roomdevices-macros-samples/tree/master/Customer%20Satisfaction as a couple of examples.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Wayne,
Could you let me know if we can custom on screen this command : UserInterface Message Alert Display
On my SX10 this message appears on top right corner and I would like to see it in center of my screen.
Behind this question : I would like to adapt this script  : customersatisfaction.js but I would like to use the screen as message support and not the touch panel - this UserInterface Message Alert Display appears good to replace UserInterface Message Prompt Display - but do you know if another command exists to display the text in center of screen.
Thank in advance.
Hi @StephaneTrapp75469,
the command you are looking for is
xcommand UserInterface Message TextLine Display Duration: 20 Text: "Hello, how are you?"
Best regards
Igor
