setting read write on a DMP from the DMM system tasks
Need to be able to set the read/write parameter on the internal memeory on a DMP from the Advanced Task area of the 5.0 DMM.
Anyone done this before?
Thanks.
didyap
Level 6
Level 6
The "Admin" user role is assigned automatically to any user who is an administrator in any DMM software module. These users have full read/write access to all users and user groups in DMS-Admin and can manage settings for them.
For the further description following URL may help you
http://www.cisco.com/en/US/docs/video/digital_media_systems/5_x/5_0/dmm/user/guide/conset.html
Thanks for the note.
I have since found out how I cabn do this from the DMS.
Under the DMP pages you can go to Advanced Tasks.
Select System Tasks and then click on Add Application.
Set the name something unique like SD-Read-Write.
Have "Set" selected
for the parameter have
init.sd_rw=1
This will set the internal SD Memory to Read/Write
Click on Submit and you are done.
You can then add this as the first step when Transfering a presentation to a DMP so that you know that the DMP will accept the presentation.
