show policy-map interface gi 1/0 in
alex goshtaei
Beginner
Beginner
is there anyway to see source IP address coming to interface gi 1/0 when apply QoS? there are multiple IPs coming to interface gi 1/0, but I need to know which IP address is matched to which class-map. below command only shows accumulated packets per each class-map.
thanks
Alex
Jaime Valencia
You probably want to try some other area, you posted this in the Video Over IP forum.
java
if this helps, please rate
Hi Alex,
As Jamie Valencia wrote, you've posted this query in the Video Over IP section of the forums which is more geared to the actual Video hardware products than the switches and routers.  I'd suggest that you consider moving your post (which you can do via the Edit button on your original post) to another section of the forums where the network devices are more actively discussed, such as the LAN Switching and Routing section.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
