Sizing bandwidth requirements
ruben.montes
what info do you use in order to size the WAN links accordingly? I have some quite old docs that I used, but I think in latest releases bandwidth consumption has been reduced a 20%. How do you size the link to tell the customer the badwidth they need ? Is the info in the administration guide of the endpoint useful for this purpose?
Thi is an example for the MX200:
Ruben
aostense
Hi Ruben,
Endpoints bandwidth per resolution may vary, so this information is normally listed in the administrator guide of the systems.
For TC6 and MX-series, here is the new matrix:
Hope this helps, and let me know if you are looking for a similar matrix for other endpoints.
Best regards,
Arne
aostense
Hi Ruben,
Best regards,
Arne
