SNMP On Cisco EX60
joshua.oglesby1
Hello all,
In regards to SNMP on the EX60 ,I was curious if there was a default Read/Write community string for the device? Trying to manage my devices through Solar Winds. I am not using TMS.
I am able to connect to the device with the Public community string, but as far as the Read/Write community string, I cant connect due to not knowing if there is a default Read/Write community string.
All feedback is and will be greatly appreciated.
-Josh
Patrick Sparkman
Default SNMP community name is either "public" or "Public", it's documented in the EX Series Admin Guide on pg 85. Have you enabled SNMP read/write on the endpoint, under Configuration > System Configuraiton > NetworkServices > SNMP?
Yes, Nothing in the guide seems to fulfill what i am looking for.
I am able to connect perfectly fine without Read/Write Permissions. Once i enable it to Read/Write and restart the EX60, i cant connect due to not knowing that the Community name is.
Solar Winds is asking for the Read/Write Community name and no where on the EX60 can i/have i configured this detail. That's why i'm assuming there must be a default one somewhere.
