12-01-2018 02:48 AM - edited 03-18-2019 02:29 PM
Any one out there having the following issue trying to SSH into a DX, MX, series Codec ???
CE9.1.3 version and CE8.2.3 version:
I use putty and see the login: than enter the admin and right after entering password, SSH disappears ???
This is happening to DX's right out of the box too.
Thanks.
Solved! Go to Solution.
12-27-2018 04:43 PM
I have no issues with putty connecting to any of my devices. Check that your version of putty is up to date - the current version is 0.70.
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-01-2018 07:57 AM
I have no issues logging into my DX units over SSH. I would consider this to be a problem with Putty. A quick google search shows that there have been several instances of putty just closing after a successful login. I would first try to follow that path to figure out if it may be an issue with your putty client.
/Magnus
12-27-2018 04:43 PM
