01-07-2013 03:36 PM - edited 03-18-2019 12:23 AM
is it possible to stack a fully licensed 5310 and a fully licensed 5320 MCU together to make a single 30x 720p30 port MCU?
thanks!
Solved! Go to Solution.
01-07-2013 06:03 PM
01-07-2013 06:00 PM
Yes it is possible, there is a document/powerpoint somewhere that shows the different scenarios, but I can't remember where I've seen it at. Basically to my understanding, you can stack any combination of the two up to a max of two MCUs.
01-07-2013 06:03 PM
01-07-2013 06:17 PM
Dude this is exactly what I needed! thanks a ton for digging this up.
Sent from Cisco Technical Support Android App
