SX10 codec- Need to use line input
arifpatil
Beginner
Beginner
We are using SX10 codec & we need to use a balance line signal out from Biamp Nexia DSP as a Mic input to this codec. We are connecting 3 mics in Nexia DSP & mix Balance out will go to Mic In of SX10 codec for far end participants.
The 4 pin connector pinout given by cisco is 1, 2, 3, 4 = T, R1, R2, S = Hot+, Cold-, Mic control, Ground respectively.
We are using 4 pin connector with the signal Hot+, Cold- , Ground as pins 1, 2, 4 respectively. We are not using pin 3 as Mic control for Mute/Unmute button.
By using this connection we are not able to get audio at far end.
Do we need to short pin 3 & 4 for grounding Mic control to work this?
If we use External Mic of Cisco, it works fine.
Please share the solution..
This might answer your questions, since the SX20 uses the same type of microphone connector.
connect-third-party-microphone-to-cisco
How do i connect multiple (3) mics using this setup?
You can use use an external microphone mixer to mix the audio of the three microphones together and then send them out a single output into the SX10.
Recognize Your Peers
