sx20 call
itay00002
hi
i share my computer on both screens via the unit(in dual mode) and wants to make a call
when i dail, the unit is still showing my computer on both screens and not the actual call and i need to stop sharing my computer
to see the other side or the call proccess and then share the computer again
is that how it suppose to be? is there a setting that i can change that if i try to call the screen will start showing the call proccess and not stay on sharing mode? at least 1 screen show the call process and the other one will still show the computer that i am sharing?
thanks.....
6 Replies 6
Jens Didriksen
Level 9
Level 9
Normal procedure is to first establish the call, then start the presentation.
It would help if you posted the xconfiguration details.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
is this help?
please see attachment
What software version is it running?
/jens
Current version
TC7.3.0.8cb420c
Ok, I haven't upgraded any of our systems to TC7.3 as yet, currently running TC7.2.1.
Anyways, I would set
General Settings, Monitors to either "Dual" (as you have) or "DualPresentationOnly"
OSD AutoSelectPresentationSource to "Off" (this will stop the PC from being displayed as soon as you connect your PC and you'll either see the wallpaper or selfview depending on your preferences.)
Output HDMI1 - MonitorRole to "First"
Output HDMI2 - MonitorRole to either "Second" or "PresentationOnly"
/jens
Hi ,
Kindly check in advanced setting than video and than output HDMI
