SX20 : how to configure default SIP extension
CNS
Beginner
Beginner
Hi, How can we configure the default extension when calling a SIP address ?
So far, when we use the shortname of a unit (for example 2221), the system automatically appends a wrong SIP extension {@xrce.xeroxlabs.com). We would like the system to add instead the right extension which is @10.64.84.20. Where do we specify this in the System settings please ?
Syed
Participant
Participant
Login to SX20 - System Configuration - SIP - change URI and save.
Thanks for your answer,
But when we call 2201 for example, we had 2201@xrce.xeroxlabs.com and I want : 2201@10.64.84.20
I want to change this one : @"..."
What protocol are you using when dialing from the SX20?
Is the SX20 registered to a call control server, or is standalone?
