Sx20 log message
Mahmoud Simrin
is there anything wrong with the followingmessage
: invalid timestamps, disabling insert fill. Current 3130452196, predicted 3130450396, predictedData 3130450396, AACLD_64
2019-06-18T09:01:20.000-04:00 TP-US-WFC-22-100-SX20 vcodec: 1623997.28 DEC_FSM-0 I: create H.264NIL width=1920 height=1088 mbps=486000 dec=ttvdec_h264_ivahd
Wayne DeNardi
Are you able to provide a description of the issue you are trying to diagnose which may help us provide you with a better idea of what you could be doing to fix it than a single line from a log file.
But, given that it has issues with timestamps, one thing I would be checking is the NTP server settings (and the fact that the endpoint can actually connect to the speficied NTP server) so that it gets the correct time.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
