sx20 problem
JS
Beginner
Beginner
SX20 is installed in the local office
Problem faced:
1) Not able to make outgoing call to test site. (But able to ping the SIP from notebook/pc)
2) VC drop straight out when trying to connect.
3) URL/Web interface to VC - H.323 setting are not populated.
how should i go about to troubleshoot.
Paul Woelfel
Enthusiast
Enthusiast
Have you got a firewall in between?
I would check if you an reach 5060/5061 TCP, 1719 UDP and 1720 TCP?
which DefaultCall Protocol do you use?
Are you behind a Nat?
Regards, Paul
