SX20 - Restart is Disaled (grey)
Shy Solenko
While trying to restart the system remotely via web access, I get the following screen:
(restart is locked and grayed out)
In other 2 Cisco units I have (C40 and SX20) I CAN reset remotely)
Where is the setup for this and how do I change it?
amehla
Hi Shy,
i guess you had enabled the strong security mode on your device which disable factory reset from web interface.
try to disable it and try again.
Ravi Yadav
Level 4
Level 4
Hi Shy,
As amit said you can ceck the security mode.
Along with that please confirm if you are logging as admin or a user.
Is this sx20 codec provisioned to tms or standalone?
Ravi kr.
Sent from Cisco Technical Support Android App
Ravi Yadav
Level 4
Level 4
Hi Shy,
could you check and share the logs for
"systemtools securitystatus"
log in as admin and run the command.
Ravi kr.
