05-23-2018 10:05 AM - edited 03-18-2019 02:07 PM
We are trying to figure out when Cisco took out the security access Pin option in the CE upgrades? I have a client that would like to have that option, and in the Quick Set Admin Guide, p.19 (v.9.0) it says that it is available through the Security Tab. In version 9.2.X that they are running, this option is not available anymore... is there a reason behind it?
Link to guide:
9.0 (p.19): https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce90/sx20-administrator-guide-ce90.pdf
9.1 (p.21): https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce91/sx20-administrator-guide-ce91.pdf
9.2 (p.7 / missing): https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce92/sx20-administrator-guide-ce92.pdf
Solved! Go to Solution.
05-24-2018 06:18 AM
05-24-2018 06:18 AM
08-22-2019 11:32 AM
is there a way to require a pin on the touch panel just to make a call? The old Android DX80s used to have this option.
