SX20 Security Risk
Timmy Tommy
i can see message on the my Display ("Security risk: System password not set Please Contact the system administrator") when i switch on my SX20. i have checked option and release key in the box but nothing is there. Please can you explain it.
Teck Chye Tang
From TC6.x softwae release, you will get a security warning if you do not set any Admin password.
so you should set a password for your system or If you do not wish to set a password, then you can do this :
xCommand SystemUnit AdminPassword Set password : ""
Once you do that, you will not see the warning.
regards,
Teck Chye Tang
regards,
Dear Teckchye
Thanks for reply me. your answer is correctly.
sorry for reply late.
