SX20 Security Risk
Timmy Tommy
Beginner
Beginner
i can see message on the my Display ("Security risk: System password not set Please Contact the system administrator") when i switch on my SX20. i have checked option and release key in the box but nothing is there. Please can you explain it.
Teck Chye Tang
From TC6.x softwae release, you will get a security warning if you do not set any Admin password.
so you should set a password for your system or If you do not wish to set a password, then you can do this :
xCommand SystemUnit AdminPassword Set password : ""
Once you do that, you will not see the warning.
regards,
Teck Chye Tang
regards,
Dear Teckchye
Thanks for reply me. your answer is correctly.
sorry for reply late.
Recognize Your Peers
