SX80 causing meter bounce
John Lang
We have several SX80s connected to Soundstructure DSPs and there is a rhythmic, constant bounce on the codec meter of the DSP.
We have grounded everything, filtered the power, check and rechecked the wiring and isolated the source to the SX80.
If the levels are set to high in the DSP then there is a repeating clicking that matches the meter movement.
Any thoughts?
Patrick Sparkman
You and another user might have a similar issue, sx80-speaker-noise, both reporting something coming from the speakers.  I know the IX5000 had a similar issue recently, CSCva98522, maybe the SX80 is too.
Is Proximity enabled, if so, try turning it off and check?  Otherwise, probably best to contact TAC if it's something to be an issue when the system in idle or in use.
Patrick Sparkman
John Lang
Thank you Sir,
That removed the bounce and the clicking noise. Now if we can just do something about this awful A/C unit above the room :-)
