SX80 Presentation Automation
I am trying to automate when you are in a call and when you share a presentation it goes to both displays. But when you stop sharing the displays go to far/near. Currently I can do this with a GPIO tied to a Crestron processor and then the Crestron sends xCommands to the SX80 to change this. Is there a way to internally automate this within the SX80 without the use of a Crestron processor?
Patrick Sparkman
Currently not possible, you’ll need to use the API to achieve this like you’re doing now. Another option is if you’re running TC software, you might be able to use TC Console to edit the layouts.
Thanks. Hopefully it will be possible to build some logic into the SX80 at some point to simplify integration.
