SX80 Speaker Noise
IsenLin
Level 4
Level 4
Hello~SX80 just connect line1 of output to mixer,Not connected other devices
Just take a line,But the mixer has an intermittent noise detection.
How to remove SX80 noise?
Isen Lin
Patrick Sparkman
You and another user might have a similar issue, sx80-causing-meter-bounce, both reporting something coming from the speakers.  I know the IX5000 had a similar issue recently, CSCva98522, maybe the SX80 is too.
Is Proximity enabled, if so, try turning it off and check?  Otherwise, probably best to contact TAC if it's something to be an issue when the system in idle or in use.
Patrick Sparkman
I fix it. Just Proximity trun off.
Thank you.
Isen Lin
We have also a recurring sound on our sx-80, it appears every 35 sec and the log shows:
2016-11-21T09:40:09.037+01:00 LOWS4-1-DGITEC appl[1248]: 227964.79 audiocontroller.log I: file_play_retry log 105 /sounds/PresentationConnect.wav
2016-11-21T09:40:44.445+01:00 LOWS4-1-DGITEC appl[1248]: 228000.20 audiocontroller.log I: file_play_req log 105 /sounds/PresentationConnect.wav
2016-11-21T09:40:44.446+01:00 LOWS4-1-DGITEC appl[1248]: 228000.20 audiocontroller.log I: file_stop_req log 105
2016-11-21T09:40:44.456+01:00 LOWS4-1-DGITEC appl[1248]: 228000.21 audiocontroller.log I: file_play_req log 105 /sounds/PresentationConnect.wav
2016-11-21T09:40:44.458+01:00 LOWS4-1-DGITEC appl[1248]: 228000.21 audiocontroller.log I: file_play_retry log 105 /sounds/PresentationConnect.wav
2016-11-21T09:41:19.923+01:00 LOWS4-1-DGITEC appl[1248]: 228035.68 audiocontroller.log I: file_play_req log 105 /sounds/PresentationConnect.wav
