SX80 xcommand to add second call
andrewhansen471
Has anyone been able to add a second call in an active call using xcommands and merge the calls?
Thanks for the help
Andrew
2 Accepted Solutions
Manish Gogna
Hi Andrew,
I tried some days ago on the SX20 in my lab using the following command and it did work
xCommand Call Join
Manish
Patrick Sparkman
In addition to what Manish has provided, if you search the forums there are some examples of how to do this, here is one that comes to mind: sx20-it-says-max-number-calls-reached.  Also, refer to the SX Series API Guides.
Manish Gogna
Hi Andrew,
xCommand Call Join
Manish
Thanks Pat and Manish
I will give it a try on my sx80
Andrew
Patrick Sparkman
