07-19-2016 10:53 PM - edited 03-18-2019 06:09 AM
Has anyone been able to add a second call in an active call using xcommands and merge the calls?
Thanks for the help
Andrew
Solved! Go to Solution.
07-20-2016 04:00 AM
Hi Andrew,
I tried some days ago on the SX20 in my lab using the following command and it did work
xCommand Call Join
Manish
07-20-2016 07:01 AM
In addition to what Manish has provided, if you search the forums there are some examples of how to do this, here is one that comes to mind: sx20-it-says-max-number-calls-reached. Also, refer to the SX Series API Guides.
07-20-2016 04:00 AM
Hi Andrew,
xCommand Call Join
Manish
07-20-2016 02:35 PM
Thanks Pat and Manish
I will give it a try on my sx80
Andrew
07-20-2016 07:01 AM
