T3 change ssh and vnc password
Hi all,
Any one know how i can change ssh and vnc password on TCU 4.2.1 ?
Best regards
Artemisio
Marius Nedregaard
Hi Artemisio.
This is described in the T3 admistrator guide.
http://www.cisco.com/en/US/docs/telepresence/endpoint/t3/guides/t1_t3_admin_guide_tcu421.pdf
at page 9 you can see
Changing Default TCU Password
You will need to be physically connected to change the password. Attach a USB
keyboard to the TCU (or use the VNC server—available from TCU2.0) and press
Ctrl-Shft-Esc to bring up the Windows Task Manager. Select “File” – “New Task
(Run…)” key in “cmd” and press return to bring up the Command Line Interface.
1. Set the new password with “net user Administrator ”.
2. Run the command “control userpasswords2” and you will get a new window
up.
3. Check the box “users must enter a user name and password to use this
computer” and click Apply.
4. Same as above, but uncheck the box and click OK. You will be prompted with
a new password box, use your new password here.
5. Reboot.
//Marius
Hi Marius,
I followed this procedure, but is used only to change the password for access to the TCU. I'm looking for the procedure to change the password VNC and SSH.
Thanks for the reply.
greetings
Artemisio
