Tandberg 1700 audio issue
salem
We have a tandberg 1700 mxp desktop video conferencing device
Audio not working no speaker no mic
I checked speaker and mic in menu but no sound in speaker and mic not working.
Could you please help me?
Leonardo Santana
This device is too old.
I suggest you upgrade to a modern device.
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
As @Leonardo Santana mentioned, the Tandberg 1700 MXP wend end of sale in February 2012 (10 years ago!) and End of Support on 28 February 2017 (5 years ago!) - so it is an extremely old and outdated device.
You could try resetting the device back to factory settings (taking note of any option keys first so you can re-add them afterwards) to see if that helps things - but, if it's a hardware issue (and being a 10+ year old device that's quite likely) there's probably not a lot you can do easily to fix it.
A newer and supportable model would be the best recommendation.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
