01-23-2013 12:34 PM - edited 03-18-2019 12:28 AM
Hello
I have a tandber endpoint that has access to internet througt an ASA firewall, the thing is we had some trouble stablishing calls recently and testing the device with another endpoint outside the network, the call got established when we set the NAT configuration of our tandberg in nothing.
And Im trying to understand why is it working in that configuration? doesnt it have to work with the NAT option set? because its behind a firewall...
Appreaciate the comments.
Thank you.
01-23-2013 12:46 PM
If you would tell us a bit about the deployment, like stand alone/registered to a VCS or BC
which protocol you use (h323/sip), which system type and software version it is, what you try
to dial (uri, ip, ...), how the asa is configured and so on.
Just that something might not be properly deployed does not mean that parts could not work. :-)
01-25-2013 12:00 PM
Thank you for the quick answer,
The endpoint is registered to a VCS, we are using h323 and we are trying to dial an ip address, the ASA is configured to let everything from the public IP of the other office to have full access to our endpoint
Why could it be working without NAT? thats the question Im trying to answer, could the ASA be blocking something with the IPS when the endpoint sets the h323 headers with the public ip?
Best regards
01-26-2013 02:20 AM
Is it a VCS-C or -E? The VCS-E is designed to do the firewall traversal.
It depends a bit on what you expect whats possible to dial.
If you have the system registered to the expressway all other protocol based
NAT handling should be turned off as the VCS-E is doing the magic and just
gets confused if something else is trying to know it better.
This would be on the endpoint but also on the firewall. So no NAT setting on your endpoint
and on the ASA.
This enables you to use inbound and outbound uri and e164 dialing for h323 and uri for sip.
