TC7.0 blocking iframes for TelePresence VC
advertiseme
Does anyone know how to bypass or allow iframes for Cisco TelePresence SX20, C40 using TC7.0
We were able to display snapshots using iframes on TC5.1 but it's now no longer working with TC7.0
Any help is greatly appreciated. Maybe there's a way to re-enable this setting on the web server of the VC unit?
One easy (but not necessarily secure) way is to add the credentials in to the URL, ie:
http://username:password@x.x.x.x/websnapshot/get
The refresh can be done within the HTML HEAD element, ie to refresh every 30 seconds:
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
11 Replies 11
Wayne DeNardi
From TC6 the path for the websnapshot changed from /wsgi/translation to /web/translation.  That may be your issue.
Edit: Sorry, the above was for the touchpanel snaptshots... the websnapshots are at /websnapshot/get
Note: the websnapshots must be enabled on the device - I've seen the odd one or two loose this setting following an upgrade and it having to be re-enabled on the device.
Wayne
Wayne
Thanks for your reply Wayne.
I did notice that the URL was changed from wsgi to web however the login page still does load in an iframe.
Debugging using Chrome Dev console I get:
Refused to display '
http://xxx.xxx.xx.xx/web/signin?next=/web/call
' in a frame because it set 'X-Frame-Options' to 'DENY
Is there a reason you're going to that URL ant not just directly to "http://xxx.xxx.xx.xx/websnapshot/get" for the snapshot?
Wayne
Wayne
Wayne,
That was just an example to get the X-Frame-Options.
The same thing happens when going to websnapshot/get or any url on the VC:
Refused to display 'http://xx.xx.xx.xx/websnapshot/get' in a frame because it set 'X-Frame-Options' to 'DENY'.
The reason why we are using iframes is because we want to include several snapshots on the one page.
I've done similar, but just used a table of the images from /websnapshot/get (and refresh the page very 30 seconds) - lots of:
  http://XXX.XXX.XX.XX/websnapshot/get" WIDTH="320" HEIGHT="180" BORDER="1">
Wayne
Wayne
Never thought of using the IMG tag.
That is a winner. How did you automatically authenticate to the VC unit and refreshed the page?
Wayne
Wayne
You are a legend Wayne. We will try this method then.
Happy to be of assistance.
Wayne
Wayne
Love the Cisco Support Community.
