TCL Script - doesn´t collect called extension digit
m.hofer
I configured a application to a "dail-peer voice pots". The problem occures only by incoming called extensions with obverlap receiving.
Which commands do I need that all digits gets collected?
Thanks a lot
Regards Martin
ebreniz
Level 6
Level 6
If you are using QSIG signalling You must create the application that is to be called to interact with the dial peer (that collects the digits from the caller) before you configure the dial peer that will call this application.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008020ecf1.html
